Reply To: H9 Presets and Midi values
Home Forums Products Stompboxes H9 Presets and Midi values Reply To: H9 Presets and Midi values
#143814
gkellum
dazza wrote:
is there a way to see the preset number from within the h9 control?
Yes, if you click on the Pedal button in the bottom menubar of H9 Control, go to MIDI Settings, and to Program Change Receive Map, that is the aforementioned map.  The default program change receive map is sequential.  Did you buy your H9 from someone?  If you want to reset it's system settings to restore its program change receive map to its default state, you can turn it off and the turn it on witht the right footswitch and the HotKnob button pressed (the button in the upper left hand corner of the H9).
