Home Forums Products Stompboxes H9 Bypass options Reply To: H9 Bypass options
#143837
    It partly depends on whether you have a serial or parallel effects loop.
    If the former, you should have killdry off.
    If the latter and only one pedal you should have killdry on. If more than one pedal, you can't use killdry as it will mute when bypassed, but if all pedals are bypassed you will double the volume – parallel loops don't work well with multiple pedals.
