Home Forums Products Stompboxes H9 MIDI Problems Reply To: H9 MIDI Problems
#143862
Alancarl
    gkellum wrote:
    By the way you don't have a USB cable plugged into the H9 at the same time, b/c that can screw things up…
    As I have discovered the H9 will not pass midi on thru if a USB cable/host device is connected.
    I can imagine that midi merge or midi output settings might cause problems with USB hooked up and sending/receiving MIDI…but I do have other devices that do treat the 5 pin din ports separately from the USB route.
    Can Eventide at least enable midi thru with USB connected?
    Also one huge discovery for me is that my iPad with a USB camera connection kit and a hub will allo me to connect multiple H9’s and switch between devices from the H9 control app!
    With Bluetooth and Apple having enough flakiness and restrictions I am totally thrilled to be able to hardwire this mission critical control application.
    Hopefully the midi thru can coexist with th USB connected.
    Thanks,
    Al
