Home Forums Products Stompboxes H9 MIDI Problems Reply To: H9 MIDI Problems
#143863
    As has been mentioned in other posts, you cannot have both USB and DIN MIDI at the same time.
    The reason for this is that we only expected USB to be used for updating the unit, and did not expect it to be used in real time.
    In fact, it is only due to luck (and driver availability) that the USB supports MIDI at all.
