Home › Forums › Products › Stompboxes › PowerFactor2 Question › Reply To: PowerFactor2 Question
July 20, 2016 at 2:42 pm
#143873
Well the 70mA figure is the actual current draw of the pedal I’ve measured. Many manufacturers state a wrong or too high figure. If you get the voltage right and the polarity and type of the plug used you are ok. You can’t overpower a pedal and an underpower meaning using a source or outlet with not sufficient mA capability will just result in that the pedal will stop working or be unstable, behave strange if it’s a digital one.
Best,
Poul Ciok
