Home Forums Products Stompboxes modFactor preset levels Reply To: modFactor preset levels
#143877
gkellum
    pjwassermann wrote:
    It would still be great to get an answer if this level fader in H9Control is working for ModFactor or not.
    We just tested it, and it's working fine.  Could you reset the system settings of your ModFactor to see if that helps?  Sometimes, the system settings get messed up after installing a software update, and then you start seeing all kinds of strange behavior.  To do so, turn your ModFactor off, and then turn it on again with the right footswitch and the algorithm selection encoder pressed.  This will clear out the system settings, but won't affect your presets.
