Home › Forums › Products › Stompboxes › H9 MIDI Problems › Reply To: H9 MIDI Problems
#143900
    alancarl wrote:
    Hi Eventides, I understand that USB and midi cannot be used simultaneously with the H9… In my rig I am switching between the two protocols and I have both hooked up and data at times is being sent to both. When I shut off the USB pipe the midi them takes over. Is this potentially problematic having both connected and sending? It seems like when the H9 makes its USB connection it shuts the midi din ports off. Thanks a lot. I really love the H9's! Al
    You can have them both connected – when the USB is removed, the pedal spots that the 5V usb power has gone away, and switches over to DIN. (The USB has priority).
