Reply To: Program change receive map problem.
Home Forums Products Stompboxes Program change receive map problem. Reply To: Program change receive map problem.
#143974
awin1805
Hi Nick,
I have checked the PC change map in h9 control and have found that the map is not as factory. Aside from the few that I have changed, as mentioned in my original post, the rest of the map currently reads: 0:1, 1:2, 2:3. etc. It seems that according to the map, every input number should give me a preset one number higher.
This is confusing because in actual real world use, the h9 gives me the same preset number as the input number no matter what I do to the map. The h9 is completely ignoring the PC change map.
I have checked the h9 itself to see if any of my own mapped presets have been stored on the unit and they have.
Whilst this problem is awkward and confusing, I can work around it if needs be, it does not spoil my enjoyment of the h9.
Hope this helps. Andrew
