Home Forums Products Stompboxes Program change receive map problem. Reply To: Program change receive map problem.
#143992
    As far as we can see, it all works as expected. I assume you are using the latest versions of H9 and H9 control.
    Since you are using H9Control, it would be helpful if you would:
    1) Look at the RCV.MAP on the H9 and see if it corresponds to what you see on H9Control.
    2) Try adjusting a couple of map entries diredly on the H9, and see if they do what you would expect.
