Home Forums Products Plug-Ins newbie question Reply To: newbie question
#143995
tlongabaugh
    Hi fatharock-
    Regarding the path to the H910, make sure that you have the correct 32-bit/64-bit path specified for the version of Reaper you are using (32/64-bit). You could also try a "rescan" of the plug-ins. Of course, it's also fine to put the H910 in the Reaper plug-in folder if you like, providing it's the correct 32 or 64-bit version.
    Could you give me a bit more info into exactly how Komplete crashes? Does this happen when you try and instantiate the H910, or simply if the H910 is in the plug-in folder at all? Does an error message pop up when it crashes? If so, could you post it here? If you open H910, and then Komplete, does Komplete load then?
    Best,
    Tom
