Home › Forums › Products › Stompboxes › ModFactor: Issue with Midi change after an update to 5.2 › Reply To: ModFactor: Issue with Midi change after an update to 5.2
August 2, 2016 at 7:31 pm
#144002
sateven wrote:
I carefully check the parameters but I probably miss something?
Maybe, this wasn't always true, but nowadays, if you save a preset as bypassed, when you load a preset with a MIDI program change, it will load as bypassed. If you save it as active, it will load as active. So, please check and make sure that your user presets are saved as active. You should be able to see this in H9 Control. You could also just make a preset active and resave it directly on the ModFactor.
