Home Forums Products Stompboxes Powering the Mixing Link Reply To: Powering the Mixing Link
#144017
gregsinibaldi
    Thanks jwaltz…
    FYI for folks that may run across this later… I recieved an email from Eventide support saying the following…
    Hi Greg,
    I’m sorry, but we only recommend using Eventide power supplies to power our products. The Mixing Link needs 9VDC 500mA of power to use the phantom power function, as provided by the included power supply. I don’t believe that the Pedal Power 2 + can provide that. Sorry.
    Best Regards,
    Jerome Hyman
    Audio Support Technician
    Tel: 201-641-1200
    Email: jhyman@eventide.com
    That said, I used the current doubleing cable with 2 ports from VodooLabs power 2+ (ports 1 and 2, which each provide 100mA of current, so 200mA total) and the eventide works fine. The VodooLabs power 2+ also has two ports that send higher current (ports 5 and 6 send 250mA each so with a current doubling cable you can reach the suggested curret draw (500mA) recommended by Eventide)
