Home › Forums › Products › Stompboxes › H9 as a MIDI Controller › Reply To: H9 as a MIDI Controller
        August 3, 2016 at 10:58 pm
        #144022
alancarl wrote:
My question…can the H9 be set to transmit the values of any parameter assigned to transmit a CC upon a preset load?
If I understand you correctly, when a new preset is loaded on an H9, you'd like it to send out the values of one or more of that presets' parameters as MIDI CC messages?
The H9 doesn't do that. It can send out MIDI CC messages when you're changing a particular parameter, but it only does that in response to a user changing a parameter and not to preset loads.
