Home › Forums › Products › Stompboxes › H9 as a MIDI Controller › Reply To: H9 as a MIDI Controller
#144023
Alancarl
    gkellum wrote:
    alancarl wrote:
    My question…can the H9 be set to transmit the values of any parameter assigned to transmit a CC upon a preset load?
    If I understand you correctly, when a new preset is loaded on an H9, you'd like it to send out the values of one or more of that presets' parameters as MIDI CC messages?
    The H9 doesn't do that. It can send out MIDI CC messages when you're changing a particular parameter, but it only does that in response to a user changing a parameter and not to preset loads.
    Yes this would give a parameter feedback reference on a generic midi knob controller device and it would give an endless rotary encoder a starting position that corresponds to the H9 parameter values for any given preset as opposed to having to reach the null point before the parameter changes.
    Thanks for a really terrific product!
    Al
