Reply To: H9 kill dry function issue
Home Forums Products Stompboxes H9 kill dry function issue Reply To: H9 kill dry function issue
#144065
DGillespie
Hi satch4u4,
Are you feeding the inputs from all these out of the amp loop, or are they feeding into one another?  If you're going to run from a parallel effects loop you need to run all the pedals in parallel and sum the otputs.  It sounds like you're summing the outputs, but you need to use a splitter cable to feed them all from the amp.
Dan
