Home Forums Products Stompboxes H9 with Midi Peak FCB2N Reply To: H9 with Midi Peak FCB2N
#144075
gkellum wrote:
acroxixo wrote:
What I whant is to active/bypass, increase and decrease presets on the Peak FCB2N.
From what I can tell that MIDI footswitch sends out program change messages on the left and right switches and MIDI CC messages on the center switch. Isn't it already increasing and decreasing the presets?
In H9 Control if you click the Pedal button in the bottom menubar and go to MIDI Settings, you'll see a button labelled "Assign MIDI CC messages to pedal functions" and another labelled "Program change receive map".  That's where you can set up what particular kinds of MIDI messages do on the H9.  You'll most likely want to go to Assign MIDI CC messages to pedal functions / Toggle between Active and Bypass for the active/bypass function.
Thank you for the reply.
But it’s like the midi pedal isn’t connected to the H9, but it is.
It’s possible not recognise the midi pedal?
I search at Peak website and they have a instruction guide for the Peak FCB2N. I did everything, but it’s not happening.
Maybe I changed some settings on H9 and I don’t know at it is. Not even increase ou decrease presets.
