Home Forums Products Stompboxes H9 automatic double track patch? Reply To: H9 automatic double track patch?
#144120
    The MicroPitch algorithm is good for this, because it can blend three subtle pitch variations together.  But I’ll bet that about 1/3 of all algorithms are capable of some kind of doubling & ambient effect.
    So focus on the algorithm type that offers the most control over what’s important (to you):  pitch variations, timing delays, EQ fine tuning, picking strength, modulation of the delays, etc.  All feature panned positioning, so a multi-channel, multi-amp, or stereo setup helps to ‘sell’ the illusion.
    I like to map the PITCH / DELAY MIX control to an expression pedal, for varying the timing in real time.  Many of the preset FX below are mixed back.  You may want to start at a 50:50 MIX, and adjust it from there.
    An algorithm sampler:
