Home Forums Products Stompboxes TimeFactor Not Connecting Via USB Reply To: TimeFactor Not Connecting Via USB
#144230
gkellum
    Paquette wrote:
    H9 control stopped communicating with the pedal this morning. I changed the cable, I changed the USB port and I even tried with a different computer.
    So, when you connect H9 Control to your pedal, it's unable to connect to the pedal immediately?  Or do you see Communication Error messages when you are trying to do specific things with H9 Control and your pedal?  Was the behavior exactly the same on the other computer?
    It's quite odd that you would be able to update the pedal but not use H9 Control.
