Home › Forums › Products › Stompboxes › TimeFactor Not Connecting Via USB › Reply To: TimeFactor Not Connecting Via USB
#144248
Paquette
    Hi, it is indeed in the device manager section. Again, if I perform a reset (and remove the presets), it works just fine right after.
    I also tried with a MIDI-USB adapter (using the MIDI in/out on the timefactor) and same result after manually selecting the MIDI interface in H9 Control.
    Thanks
