Home Forums Products Vsig and Preset Development Space Freeze function in VSig Reply To: Space Freeze function in VSig
#144252
    marvingain wrote:
    So that's all it is to the Space freeze function? Setting a reverb decay time to 1000 sec should be close enough then? Or is there a way to set it to true infinite? Clickless kill should be able to be achieved via the iswitch module?
    1000 seconds should be enough … don't forget to cut the input as well.
    ISWITCH sounds relevant, but that bit is for you to work out.
