Reply To: Newbie Question- aux switches and expression pedals for the H9
Home Forums Products Stompboxes Newbie Question- aux switches and expression pedals for the H9 Reply To: Newbie Question- aux switches and expression pedals for the H9
#144285
DrOctabass
gkellum wrote:
DrOctabass wrote:
I am looking to purchase a H9 for my bass rig.  I was looking at expression pedals (Missions Engineering SP-H9) that allow for aux switches and wanted to know if I can use a 3 button aux switch and an expression pedal with the H9.  That would allow me to bank up and down plus use the middle button for the tuner or tap tempo.  Anyone have any experience with this?
You can’t use a 3 button aux switch at the same time as an expression pedal.  The H9 has a single jack for an expression pedal or aux switch, and you can either use an expression pedal, a 3 button aux switch, or an expression pedal with a single button aux switch.
Thanks for the quick response!  Is it possible to use the MIDI in/out for the expression pedal and then use a 3 button switch?
