Home › Forums › Products › Stompboxes › Expression pedal jumping values on Timefactor › Reply To: Expression pedal jumping values on Timefactor
September 6, 2016 at 3:11 pm
#144294
Thanks for the quick replay nickrose, well it is only a couple of values, for example if I have the expression pedal totally closed (toe down) the values will jump from 100 to 96-88.. please tell me there is a fix for this problem….
nickrose wrote:
You don’t say how much the values are changing. If it goes from (say) 55 to 56 out of 100, this is probably circuit noise.
If it changes by a lot, this could be a bad cable or a hardware fault in the unit.
