Home › Forums › Products › Stompboxes › H9 Performance Switch › Reply To: H9 Performance Switch
September 6, 2016 at 5:14 pm
#144301
nickrose wrote:
Sorry – don’t understand.
If you need help with your DMC, you should contact its maker – we can’t advise.
If you need help setting up your H9, the first place to look is the User Manual (get the latest one from our Web Site).
Hi nickrose,
my question is simple really. Is it possible to have the FREEZE Function on the H9 Right Footswitch? Right now, it’s currently doing Tap Tempo. I want to use the Blackhole algorithm and use the Freeze function on the right footswitch. Does this explain things better?
