Home › Forums › Products › Stompboxes › Just hooked up the Digitech Fs3x to increment, decrement and toggle bypass… For some reason when I activate the preset hardly › Reply To: Just hooked up the Digitech Fs3x to increment, decrement and toggle bypass… For some reason when I activate the preset hardly
#144310
gkellum
    gepiva wrote:
    Just hooked up the Digitech Fs3x to increment, decrement and toggle bypass… For some reason when I activate the preset hardly any effect if at all, however, if I send hit the preset on the iPhone it's fine??? I tried reinstalling the presets and checked if I accidentally hit something but no luck as of yet???
    That's a strange sounding problem.  You say you reinstalled the presets.  Could you try resetting your H9's system settings to make sure they're not messed up.  You do this by turning it off then turning it on again with the HotKnob switch pressed (the switch in the upper left hand corner of the H9).
    If that doesn't help, could you make a quick video with your phone or whatnot and send it to us?  It's a strange problem but maybe if we see what preset your using or something like that, it might become clearer what's happening.
