Home Forums Products Stompboxes A few more operation questions Reply To: A few more operation questions
#144340
Tim Zurowski
    Marcel wrote:
    I don’t understand: when you create a new list with 12 presets (in the control software) and you upload it to the H9 and you set the size of the list in the H9 to 12….then you have: 1. In the H9 a viewable and scrollable list of 12 presets; 2. In the H9 a real list of 99 presets; 3. in the H9 Control software a list of 12 presets. So if you edit a preset on the H9 itself and download from H9 to H9 Control you have a list of 99 presets, but if you do your editting things in H9 Control then you only deal with the list of 12 presets. I edit and tweak in H9 Control, and only have to deal with a limited preset list.
    That’s how I had assumed it would wqork, but it does not work that way here for me. FWIW, I have saved the H9 Preset List to a PC. I have the H9 set to only scroll through 12 presets, which it does. However, when I save the H9 to a preset list, I can see it transferring my 12 presets, PLUS all the remaining factory presets for a total of 99. Then when I view that same preset list on my PC in H9 control, it shows all the factory presets after my 12. So when I delete one my presets, it takes a long time because it has to shift all the presets one spot. So how do I get rid of the factory presets from my prest list? Also, it would be useful to be able to select more than one preset (i.e. Shift/Click) and delete a group as desired. As it is, it takes a ton of time to delete a few presets from my list because it has to go through all 99 presets to make the change. If it was only 12, like you suggest, that would really speed things up and make it a lot easier. I must be missing something here, but so far it has not worked the way you suggest it should??
