Home Forums Products Stompboxes where is the output stage for pre/post? Reply To: where is the output stage for pre/post?
#144346
    I'm not sure that I understand even now. My best guess is that you are asking whether the preset output gain applies to the channel with the effect.
    If so the answer is yes. The non-effect channel is essentially bypassed.
    It should be easy enough to try it and demonstrate that this is the case.
