Reply To: Latency when loading pitchfactor (H9) via MIDI
Home Forums Products Stompboxes Latency when loading pitchfactor (H9) via MIDI Reply To: Latency when loading pitchfactor (H9) via MIDI
#144366
Not quite sure what you mean.
If you refer to input-output latency, this is only a few milliseconds, which is rarely a problem. It can be an issue if you do a parallel mix, when you can get some "comb-filtering", but this applies to all digital equipment. KILLDRY can be helpful here.
