Home Forums Products Stompboxes Latency when loading pitchfactor (H9) via MIDI Reply To: Latency when loading pitchfactor (H9) via MIDI
#144369
terich
    nickrose wrote:
    Not quite sure what you mean.
    If you refer to input-output latency, this is only a few milliseconds, which is rarely a problem. It can be an issue if you do a parallel mix, when you can get some “comb-filtering”, but this applies to all digital equipment. KILLDRY can be helpful here.
    So, I’m loading patches with external MIDI footswitches, and when I hit the footswitch, there is a long lag before the effect kicks in. Esepcially noticeable on pitchfactor algorithms. Is that a better explanation?
