Home Forums Products Stompboxes Can the same MIDI message toggle a H9 preset’s bypass state as well as load it? Reply To: Can the same MIDI message toggle a H9 preset’s bypass state as well as load it?
#144413
    Anything is possible, but this may be not a good idea.
    It would obviously be convenient, but I think there is a risk of getting out of step, meaning that the pedal will not do what you expect. Meaning, you hit a switch expecting the effect to sound, but instead it goes off – you may not immediately notice the problem.
    Probably better if a command does the same thing every time.
