Home › Forums › Products › Stompboxes › H9, EXP pedal + AUX switch › Reply To: H9, EXP pedal + AUX switch
September 17, 2016 at 9:28 pm
#144415
looneynina wrote:
Is it possible to connect EXP pedal and AUX switch (with three buttons) at the same time? Or should I look for a MIDI controler instead of AUX switch? I really need the instant load for presets (one for up, one for down – and the third one for bypass) and as far as I've read about it, it can only be done with external switches. And I also need an expression pedal. So, does these two go together or can I only use pedal and one button switch?
You can only use an EXP pedal with a single button AUX switch. So, you'll want to look for a MIDI controller instead of an AUX switch.
