Home Forums Products Plug-Ins 2016 Sudio Reverb not being scanned into Reaper Reply To: 2016 Sudio Reverb not being scanned into Reaper
#144425
I did all that you described above but not only did that not work but when I try to re-install the plug in I get the message that the serial # & license keys have already been used, so I’m stuck with no way to reinstall the plug in. I’m using reaper version 4.77/x64 and Windows 10. I got this offer from registering my Focusrite Scarlett 2i2. I’ve since updated my reaper to v5.24. Can you send me a new S/N & License key…I’d like to try this plug in?
TLongabaugh wrote:
Hi-
Have you tried rescanning your plug-ins from the Reaper preferences? It’s at Options->Preferences->VST->Clear cache/re-scan.
If you have tried that, please do the following:
1. Deactivate 2016 Stereo Room
2. Delete the plug-in from the following locations:
-AAX32: c:Program Files (x86)Common FilesAvidAudioPlug-InsEventide<plugin name>.aaxplugin
-AAX64: c:Program FilesCommon FilesAvidAudioPlug-InsEventide<plugin name>.aaxplugin
-VST32: c:Program Files (x86)Common FilesSteinbergVST2Eventide<plugin name>.dll
-VST64: c:Program FilesCommon FilesSteinbergVST2Eventide<plugin name>.dll
-Presets: c:Users<user name>My DocumentsEventide<plugin name>Presets
-Any custom folder you installed 2016 to.
4. Open your DAW and rescan you plug-ins, and then shut your DAW again.
5. Reinstall your plug-in, making sure you are using the latest version: https://www.eventideaudio.com/products/plugins
  If you are installing to a custom folder, make absolutely sure you are installing the correct 32 or 64-bit version.
6. Reactivate 2016 Stereo Room
6. Reopen Reaper, and if necessary, rescan your plug-ins.
Let me know how that goes.
Best,
Tom
