Home Forums Products Stompboxes Mounting Pitchfactor on Pedal Board / Flip Base? Reply To: Mounting Pitchfactor on Pedal Board / Flip Base?
#144485
kenhan
    jtm45 wrote:
    I’m in the process of changing to Temple pedal boards. The issue with the Eventide pedals is that nothing will stick to the base and I do not want to remove the rubber pad or adhere the Temple mounting hardware over the SN tag. I flipped the base over and there is a slight bit of compression from the rubber base to the circuit board. I powered up the Pitchfactor and there were no issues. I cleaned the base with alcohol prior to flipping.
    Long term, could there be any issues? It would be nice if Eventide would have blank bases available.
    I also have a Temple board on order and am interested if anyone has used it with H9. My concerns are the same as above. Will flipping the bottom plate work? Alternately, how do you remove the rubber feet?
