Home Forums Products Stompboxes Controlling H9 iOS with accelerometer Reply To: Controlling H9 iOS with accelerometer
#144486
gkellum
    JES wrote:
    When the app is connected, it seems like I can no longer switch patches with my feet.  Am I missing something in the main menu?
    You should be able to switch patches on the H9 using its footswitches even with the app connected.  Are you sure that's not working?  If MIDI isn't working in that fashion, there could be all sorts of reasons for that.  So, could you verify that you're having trouble changing presets with the footswitches on the H9 itself for now?
    JES wrote:
    And in your experience is the bluetooth connection robust enough to last for a couple hours?
    Generally speaking, yes, it should be.
