Home Forums Products Stompboxes Mounting Pitchfactor on Pedal Board / Flip Base? Reply To: Mounting Pitchfactor on Pedal Board / Flip Base?
#144489
Flipping the base caused no issues with the pitchfactor. Leave the rubber foot pad on, no need to remove, It will compress a bit. The Temple Audio mount base is about the same height as the plate outer edge bevel, it’s a solid mount to the pedal board. This might work with all of these Eventide series pedals. Upside is that you can always restore the pedal to original condition.
