Home › Forums › Products › Stompboxes › External TAP TEMPO › Reply To: External TAP TEMPO
October 1, 2016 at 4:13 am
#144522
gkellum wrote:
markosassuncao wrote:
This way didnt work.
I’ve sent a pdf with photos os step by step.
Thanks for the pdf. That was helpful. You have two things assigned to footswitch 3: ‘increment preset’ and ‘tap tempo’. You need to click on the ‘Increment Preset’ button and switch the assignment there to none. Then, footswitch 3 should just do tap tempo.
THANK YOU MY FRIEND, BUT THERE A NEW SITUATION..
WHEN THE TEMPO IS “ON” I ONLY CAN CHANGE TEMPO WITH THE BIG BOTTON.
WHEN THE TEMPO IS “OFF” I CAN CHANGE THE TEMPO WITH THE TAP/TEMPO PEDAL.
I DONT KNOW WHAT HAPPENED..
I HAVE COMPARED THE PARAMETERS BETWEEN MY TWO H9, AND ALL THE THINGS LOOK LIKE OK
PLEASE HELP ME
