Home Forums Products Stompboxes Noise/pop when changing presets with pre/post routing Reply To: Noise/pop when changing presets with pre/post routing
#144764
    Does the pop only occur when you have signal going through it ?
    If so, this may be unavoidable – there is a lot of switching going on. There are crossfades on the switches, but these will mainly change a click to a pop – it's hard to switch active signal silently.
    If it occurs without signal, this may indicate a hardware fault.
