Home Forums Products Stompboxes H9 Feature Request: Possible to keep preset in memory when midi pc loads same preset? Reply To: H9 Feature Request: Possible to keep preset in memory when midi pc loads same preset?
#144771
    Obviously it could be done int the future. One might want to add  a wrinkle that says if the preset has been changed, it will be reloaded. But then, if you have an exp pedal, which wiggles slightly this will change things. You see the sorts of problems we face.
