Home › Forums › Products › Plug-Ins › Intermittant Validation with Eventide Plugin › Reply To: Intermittant Validation with Eventide Plugin
#144832
mat herbert
    Hi Dan!
    If you contact Pace you’re likely to get the same answer i did as that’s what i posted above… you can try to extend the timeout period by right clicking on the PACE entry in task manager, click ‘properties’ and try setting startup type to ‘Automatic delayed start’ to see if that helps, again this is from Pace….
    If that doesn’t remedy it permintently then occasionally you’ll have to start it manually as i originally described.
    hth!
