Home › Forums › Products › Stompboxes › Phasing with Xone92 and Timefactor › Reply To: Phasing with Xone92 and Timefactor
November 10, 2016 at 3:19 pm
#144847
The nature of your setup is unclear to me. But, judging from the symptoms, I'm guessing that you are using send and return to the TF, with an analog wet/dry mix.
This almost never works with digital equipment – due to the processing delay, if there is any dry content in the output you will get some phasing or "comb-filtering."
It's not just an issue with our products. You would do better to use the wet/dry mix in the TF.
