Home Forums Products Stompboxes Tomefactor leftswitch is not working and also the unit is not being recognized when plug it usb Reply To: Tomefactor leftswitch is not working and also the unit is not being recognized when plug it usb
#144868
    If I were you I would return it to your vendor – he may be aware of the problems.
    The lack of Active light is probably caused by the serial number issue. It would have to come back here to have this fixed.
    Not sure what is causing your update problem, as you give little information. It could also be related to the serial number.
