Home Forums Products Stompboxes H9 does not boot anymore Reply To: H9 does not boot anymore
#144870
    If it will go through the boot sequence, you should be able to get it into update mode. If so, you could run the update which should rebuild the software.
    I'm concerned that we don't know why this happened, as it may point to some kind of hardware issue. But, my guess is that right now you are mostly interesting in getting it working.
