Home Forums Products Stompboxes H9 Undulator problems Reply To: H9 Undulator problems
#144911
well i did some more testing and i put that one h9 that has undulator on it in front of the amp instead of going in the loop..and it worked just fine.
i have a vht amp that has both send and return volume knobs for the effects loop—i put the pedal back where i usually have it and tried all different volume levels for the effects loop and still didnt work….so im guessing that the effects loop is either too loud and the algorithm is clipping?
is there a way to ajust the input level for just that algorithm?..because like i said …all the other ones work just fine.
