Home › Forums › Products › Stompboxes › [H9] Load multiple preset lists to stompbox › Reply To: [H9] Load multiple preset lists to stompbox
November 22, 2016 at 12:30 am
#144914
In return, I bow to you. We are all equalls on this good earth, yes?. :o) I appreciate that you might see value in simplicity Nina, although it might not look like it on the face of it. The true power of the system is found in the MAX H9’s incredible pallet of voices. I simply needed a way to access and channel those almost infinite possiblities, into a fast moving performance and show – along with all of the other possibilities that the amps and other effects bring. There are certainly better ways, this is just the one I chose given what I knew at the time.
Take care
Lance
