Home › Forums › Products › Stompboxes › Momentary “infinite repeat” switch › Reply To: Momentary “infinite repeat” switch
November 26, 2016 at 10:59 am
#144941
Using the parameter change option to boost the feedback is a way around, but the problem is that you will loose whatever feedback you have programmed on the preset since it will change it to the programmed minimal setting. Just havving the repeat button momentary would be much easier. Since it would not mess with the feedback it would be able to just use the function on the fly in a song without messing up the settings for the rest of it. It would be really cool if that could be included in a future update.
