Home › Forums › Products › Stompboxes › H9 Expression and Tap Switch Y Cable Setup › Reply To: H9 Expression and Tap Switch Y Cable Setup
December 4, 2016 at 1:49 pm
#145024
This is covered at length in the support section of the Web Site.
But, if your pedal goes 0-100-0, this means that it is a volume-type pedal with a stereo jack. You will either need to disconnect the wire going from the pot to the ring connection on the jack, or use a different pedal.
