Home › Forums › Products › Stompboxes › H9 Expression and Tap Switch Y Cable Setup › Reply To: H9 Expression and Tap Switch Y Cable Setup
December 4, 2016 at 3:56 pm
#145026
Hey Nick, ok actually going from 0-100-0 was one of the scenario when inwas fooling around w the parameter switch config. It doesnt do that now all it does is glitch. Say if the expression is supposed to go from 0-50 it would just jump 0(heel)-glitchy movements to ard 10- 0 (toe).
My Dunlop X should work right since it works on its own w the H9?
Yes ive read quite a bit of this issue in the support section but i still cant figure it out.
Are you sure disconnecting a wire is the answer??
Thx Nick
