Home › Forums › Products › Stompboxes › H9 Expression and Tap Switch Y Cable Setup › Reply To: H9 Expression and Tap Switch Y Cable Setup
#145027
    joszwa80 wrote:
    Are you sure disconnecting a wire is the answer??
    The wire is the answer to the 0-100-0 problem. Don't do it otherwise !!
    Not sure about your glitches. Sounds like the pedal, but you say it is OK. Make sure the Y-lead is good.
