Home › Forums › Products › Stompboxes › H9 Expression and Tap Switch Y Cable Setup › Reply To: H9 Expression and Tap Switch Y Cable Setup
December 4, 2016 at 4:49 pm
#145028
nickrose wrote:
joszwa80 wrote:
Are you sure disconnecting a wire is the answer??
The wire is the answer to the 0-100-0 problem. Don't do it otherwise !!
Ok just checking is this the correct way to wire the Y Cable or is there other methods?
Not sure about your glitches. Sounds like the pedal, but you say it is OK. Make sure the Y-lead is good.
