Home Forums Products Stompboxes Strange H9 Noise Problem Reply To: Strange H9 Noise Problem
#145082
    It may well be a hardware fault, but before you send it in, try connecting it guitar-H9-amp. Since the problem appears in channel 2, you'll need to put some dummy leads or plugs in channel 1 in and out.
    Make sure the power supply is plugged into the same place as your amp.
