Home Forums Products Stompboxes Above zero and below zero pitch on 910/940 algorithm Reply To: Above zero and below zero pitch on 910/940 algorithm
#145113
gkellum
    garbeaj wrote:
    On Pitch A and Pitch B I only see a minimum setting of 0.908 and a maximum setting of 1.092…there doesn't seem to be a way of dialing in the "-7 BELOW ZERO" and "-9 ABOVE ZERO" settings. Can anyone help me figure out how to set all these settings on my H9?
    This would be easier to dial in with the MicroPitch algorithm.  Hopefully, that would give you the same sound?  I'm guessing -7 below zero is 7 cents below the normal pitch value and -9 above zero is 9 cents above the normal pitch value?
